DavidR8's project list
DavidR8
Scrap maker
Started:
Honda CB360T resto - needs carb float adjustment, timing, horn replacement, tank and side cover paint.
CNC mill conversion - build electronic enclosure, test movement, make stuff :D
Air compressor install - run airlines and drops
Coolant mister for mill - sort out airlines, solenoid and mounting
Not Started:
Slow speed carbide grinder
Lathe DRO
CNC router VFD - replace the POS YL-620A VFD with HY VFD
5C collet adapter for lathe
Westbury engine build
Honda CB400T restoration
Catalina 22 keel removal and rebuild
Started:
Not Started:
Lathe DRO⁸
I 'spose you're gunna have a new list for us for the new year..... :rolleyes:
At the "Wrate" you have been knocking out the projects you probably have half of this list done already......
I am assuming that this is just your year end touch ups. ;)
I’ll be lucky if I knock of half of those things this year!
