Cutting HSS Lathe Bit Stock
HSS has to reach a very high temperature before it loses temper. Unless it was glowing red it's just fine.
HSS does not lose it's hardness by "overheating". That's what makes it special. It has to be heated above the critical temperature (~1850 deg. F) and cooled very slowly to anneal it. There aren't too many ways to cut it other than abrasive.
I was not pleased with my attempt at a compound angle on the top so I cut it off. I used a Zip Cut. I think that overheated. What's a better way to 3/8" stock ?
What @MrWhoopee says.
Not a chance you will ruin it. I only cool it so I can hold it without branding my paws. Ignore the blue colour when it cools or grind the blue colour off when/if you hone it.
I think that maybe you are _trying_ to cut off the end, but the saw you used didn't work. That would not be a surprise. Even among those with machine tools, actually cutting HSS is almost impossible. Grinding is just about the only way.
So if you have messed up the grind, just grind it some more ;)
