Brent H
Yo Calgary PT,
Here is the picture of the dial assembly for an 11/13 inch Utilathe (the cross feed and the compound feed use similar design) On this design there is a small knob you loosen to rotate the dial and tighten it up when you have set back to zero.
This was driving me nuts a bit as my lathe uses a "Marcel Spring" to provide the tension for the compound feed dial and uses this knob for the cross feed dial - sort of a high bred between two lathes made by the same company. Your lathe is either experiencing a worn spring or a worn spacer. You could always drill out the dial and add the knob like in the drawing here:
