Intensemonerider
I need help making a decision between the two. Which is a better more accurate machine the Craftex CX611 or King PDM-30. I would like to know opinions and experiences good and bad…
I believe the brushless motors are supposed to be better. I have a brushed dc motor on my lathe and newer versions have a brushless motor. I've replaced brushes on mine but it's a simple job.Are the Craftex VFD’s and brushless motors any good or are they problematic???!
So it sounds like the square column mills are preferable especially for resale. Which would you buy if you were buying new?they can both make good parts, i cant imagine a new one of either is more accurate than the other.
The pdm 30 is defiantly the bigger machine, bigger table, more travel, more horsepower, its going to remove metal faster, and you will be able to set up larger things...but the cx611 has the square column, which means no z axis issues, the head tilts, and no belt changes (although i understand you lose some torque at the very low rpms)
You should look at what kind of projects you have in mind, given the price difference isnt that much (at the moment, they used to be over 1000$ apart), the square column is a more convenient machine to use, but you are loosing out on capacity... bang for the buck, a used round column ...i wouldn't expect to pay more than like 1500$ on the absolute high end in Ontario for one of those used
As for brushless....an ac motor has no brushes, so essentially they are both brushless, the pdm 30 is also a dead simple machine, belt drive, the motor dies just grab another one from marketplace and put the pulley on it and away you go
Actually that is one of the only two things i dislike about my 30. lots of time i wish it had a tilting head to mill or drill holes sideways in something that mounts the table easier laying down than standing up.The tilting head sounds good on paper but is not as rigid as the non tilting head. How often would you use the tilting head?
