Very sad. I'd rather repair it but what's the point?
Very true. There are Aliexpress vendors who have packages of ORings for around $1 so I may go that route. But you are right. A lot of work. Mostly sentimental. It's from my first Sears 2HP compressor acquired now about 50 years ago.Surely there are better O-ring suppliers. Check out your nearest farm supply place.
Even so, your time is prolly worth more dancing than searching for oring suppliers.
The bowl is fine. It's the compressed dried out rubber that is tightly stuck to the plastic and crumbles when it's removed. So I suspect it's been leaking for quite some time but with me bopping around the system probably bumped it a few times dislodging it enough so the tank that would cycle the compressor every 4 to 6 hours would take it down in under 2.I’ve been lucky at my local independent hydraulic cylinder repair shop/O-ring supplier. I’ve been able to buy small quantities & odd material rings through them vs a pack of 100.
Probably wouldn’t fly at one of the chain owned shops though.
About the separator “bowl”, have a close look at the molding to make sure there aren’t any cracks. I’ve had a couple PA units fail that way (seeping).
D 😎
Thanks. That brings up an interesting question about sizing O-Rings.Hey John, you could check Princess Auto, as Tom O suggests, and you might get lucky on diameter, or maybe make up an o ring to suit? You can buy spools of o ring stock from a variety of places, maybe somewhere your way will sell to length?
I don't know how they do under extreme pressure, but I've had good results just super-gluing the damned things together at the ends (there are rubberized cyanoacrylates that'd probably be good for this). If you're in a pinch, let me know what diameter stock you need, and I'll check the spools we have at work and stuff some in an envelope, if there's a reasonable match.
The shoulder is about 0.088 deep and high. The diameter of the seat is about 1.87" Just a rough measurement.
Does one get an O-ring with a material radius of about 0.088" or closer to a diameter of 0.088" and how large? Does one select 1.87" or 1.87" plus the rubber radius or maybe minus the ribber radius to allow some stretch?
There is a hydraulic cylinder rebuilder just around the corner from you I believe, that is if you are where I think you are. He's in the industrial area just above the Butler pit. Can't recall the name but I have a cylinder I need seals for, he helped me out on one a couple of years back, good guy. I'll try for a name.The bowl is fine. It's the compressed dried out rubber that is tightly stuck to the plastic and crumbles when it's removed. So I suspect it's been leaking for quite some time but with me bopping around the system probably bumped it a few times dislodging it enough so the tank that would cycle the compressor every 4 to 6 hours would take it down in under 2.
With it removed it holds pressure for a really long time so the rest of the system is in not bad shape.
It's on my list since I really don't want to throw it out. But I also want to clean it first. Haven't had time for that just yet.Another vote for VP Systems. They were the only ones on the south island that had the part I needed to fix a cylinder on a large bandsaw some years back.
4) install the cup holder and fuzzy dice.I stopped in at VP Systems this afternoon. Just before I parked I got a text from a friend that Rick Salaga from Custom Machining on Kilpatrick Cres. had died last week. I visited him on the 4th of July and was going to head down the hill to his place after VP Systems.
The guy at VP was just great. We fitted the two O-Rings and then when I wanted to pay he wouldn't take money. I was about to go and I asked if he knew Rick. For 20 years it turns out. Rick used to go in and pick up O-Rings for various projects and get pissed off because they'd not charge him.
Now back to the O-Ring update. Left to do:
1. Add in the tubing and T for the pressure transducer in the after tank air line.
2. Tidy up the wiring.
3. Figure out how to add some LEDs beside the display that light up beside a label stating what the number means.
I will finish this project. I will finish this project. I will finish this project.
For reference, something I just bumped into (I'm on vacation this week, and what do I do (other than a canoe trip)? Look at O-rings): Parker O-Ring Handbook
Likely more than you've ever wanted to know about o-rings and other seals. Materials, chemical compatibility, behaviour under pressure, failure modes. 292 pages of o-ring excellence.
One thing it doesn't address is trying to generate a size off an existing seat, but I guess I'd have to trust the manufacturer picked a standard size, and made the parts to suit that.
