Tool Collets for small bore D bit grinder Deckel Alexander
Tool
Someone here has a D bit grinder that uses the smaller (16mm) collets.
Here are some available on eBay at a reasonable price.
If that does not get you there, here is the title
Deckel Cutter Grinder Economy Collets Inch Round- -Used​
Thanks, I just came in the door from work. I have them on the way. These might have just moved this project up to number 41......:cool:
No, mine came from a fellow in Pemberton. It only came with two collets, a .250 and another that has a .250 hole, but no slits cut in it. I figured I would use it as a reference for making a few new ones. Not sure what it's purpose was to be, unless it is a blank to finish machine in the size needed .......
