What do you have for a fixture?I tighten my collet off the mill (fixture),
Oh so close. But like this: (missing one small feature)
I agree! Maybe if the Rock or someone like that did it, but the Rock I ain't.That's strange no wrench flats on the R8 shank You could grind or maybe mill some flats on it I can't picture holding the spindle spline as you attempt to torque the collet nut being very effective.
Not only that but if the splines get buggered the quill will, at the very least, bind when you try to use it.I can't picture holding the spindle spline as you attempt to torque the collet nut being very effective.
These machines (mine included) really need a spindle locking mechanism.
So my little mill has a flat spot right on the spindle that would solve this problem I think. Is this an uncommon feature?
Yes 2 flats 180 degrees to each other. I've never actually used them and don't have a dedicated wrench that fits it.I don't think that's common. Are there two flats such than you could apply a large wrench?
Another option could be to drill a .192 or .250 hole just deep enough to use a collet style wrench. That is as long as the area is machinable.There appears to be a lot of material on your ER40 tool holder to machine flats for a counter spanner.
That is a very good point!There appears to be a lot of material on your ER40 tool holder to machine flats for a counter spanner.
I would go that route vs a spindle lock. If the lock is strong enough, the weak point may become the little alignment screw inside the R8 taper. If you are lucky, it will just shear. If you are not, it will shear, jam and really gouge the inside of your spindle.
Always sacrifice the ”cheap” component; in this case the ER40 collet holder.
A .250 hole sounds like the way to go. The only way I have to hold end mills in my machine is via the collet, so hard to mill the flats on the adaptor when it is in the machine...
Thanks everyone for the feedback. I now have a. way forward.
