Mike_will8
New Member
Was working with @Janger over the weekend on the CNC Plasma table, cutting his stock (3/8" I believe it was) into strips.
What we noticed was that, even though we were using CNC to cut straight lines, as the cut proceeded the metal was warping due to the heat to the point that the final cut pieces really were not that straight.
@CalgaryPT , @kylemp what do you two reccomend for combatting part warping, presumably from the heat buildup? (Is this a relatively common issue with thicker stock? I haven't come across the issue with thin stuff.)
Possibly related, when we went to move the parts, some of them had bonded to the supports, like the slag had pinned the parts to the supports. Could this be related?
@Janger , could you snag some pics or measurements of those flat bars to help convey the issue?
JW
JW
