Brent H
Hey folks,
So I bit the financial bullet and thanks to @Chicken lights making a pick up and delivery I was able to get a new x axis shaft and nuts for my circa 1981 Bridgeport. The combo was about $300 US so not for the squeamish and it took a bit to convince myself to get it. Essentially the spindle and nuts I had were pretty good - backlash in the middle of the table was acceptable and my cheap o power feed did the job well. There is always a “but” and my mill has a 42” table with 36” ish travel. When things are hard to move about 12” either side of centre I thought replacement was necessary. You could hear the power feed bog down and the speed drop and @Chicken lights said he would make a stop and drop - sweet!!!
The change out is fairly straight forward if you have a few things you can use. The table is bloody heavy and slides like a figure skater on ice - amazing actually. I have an adjustable roller table for my sander outfeed that you can adjust to take the load. I recommend not sliding the table full off unless there is a need.
tools are pretty simple, however, I do have a 24” screw driver (princess auto) for adjusting the backlash. My wife also donated a felt hat a few years ago for wipers and the remains fit the bill for the felt spacer you need between the split nuts. Yes, your long shaft will be riding split nuts with a soft felty area for lubrication - (minds out of the gutter!!!)
I installed a cheap Chinese power feed last year so the install will reference that as well. I can expound on that if there are some questions.
I will start the whole process in my next post - I reduce a bunch of pics to a better posting resolution.
