Casting aluminum
Garyt
Is there anyone in the Calgary area that is casting aluminum? On our restoration project we are missing a cast aluminum part it is a very simple shape but a big job to carve out of solid.
Gary T
This sorted yet?
If not, I'm wondering if you have got a foundry pattern prepared. I'm way out in Ontario, definitely not near Calgary as requested, but whoever ends up with this job will need to know.
I checked the member map we have on another forum where I mod (thehomefoundry.org), but unfortunately the only 2 pins I see in Alberta haven't been seen on the site in years.
Good luck,
Jeff
This sorted yet?
Good luck,
Jeff
Thanks Jeff I do have it in the works.
I'm curious what it looks like too. Also wasn't sure if "in the works" meant yes he has found a foundry or yes he has a pattern ready. :)
Jeff
I can help you out with CAD model but it would have to be someone else to 3D print a casting pattern if that's a preferred path.
Thanks for the offer. The part is a left and right hand and someone stole one of the parts so we have the other hand as a pattern.
The simplest and quickest method will be to use the existing casting as a pattern. If that fails then we’ll have to make a pattern. it’s simple enough that the old fashioned way of making a wood pattern by hand might be the answer. On the other hand a 3D model can be mirrored to give @Garyt his right and left handed parts.
