Browns & Boggs co. Pedal Shear CA$300
Fort Macleod, AB
What would be the capacity of that machine?
Likely to have been rated for 16 Gage Mild steel (~.063", IIRC). Rough rule of thumb was half the mild steel rating for Stainless, and twice the mild steel thickness for Aluminum sheet.
Esp for thin stock, you want the gap between anvil and blade at or a wee bit less than, 10 percent of the stock (that you are cutting) thickness, else you run a real risk of folding the material and wedging it in bent-over format, between the two.
