I have a large robust boring head which is fantastic. But because it only has one boring bar port, when I have to do large diameter bores, it is quite unbalanced, so I have to reduce the rotational speed, who wants to do that!! I have another boring head with an integral R8 arbor. It has 2 ports vertically and 1 port horizontally. But my milling machine has a 40NMTB taper. I also have and R8/40NMTB adapter. And I do not want to be changing draw bars whenever I want to use the smaller boring head.
What I need to do is put some sort of key or screw which will keep the top piece secured so it doesn't unscrew when removing the whole unit from the mill. I could Loctite it together, but I'd like to be able to remove the adapter if I have to.
