Backplate for sm9 lathe
djberta
I got an ER32 flat chuck off Amazon and I want to make a backplate for it. What I need to know is does anyone know what the spindle thread is on the standard modern 9 ultilathe? Do you guys think I can use aluminum or does it have to be medal? I do have a piece of cast iron that might work, old weirder plate weight. Or should I try to find some other cast iron to use?
The collet plate.
ER32 Collet Chuck 80mm Diameter for CNC Milling Machine Tools Carbon Steel Collet Chuck 7 Holes Chuck Lathe Collet Chuck Accuracy 0.005 ER32-D80 https://a.co/d/dAIqafL
Perhaps a commercial one can be adapted? 1-1/2 X 8 is pretty common, for example Little Machine Shop has 6 inch and 4 versions:
One thing to consider is that the spindle register on a SM may have a smaller diameter than a Southbend. I found this when I traded chucks with @YYCHM. My Chuck wouldn’t spin all the way on my SB but fit his SM.
I've got a South Bend 4J, if you want to trade the PRATT 4J back.
