Argon pressure vs flow
ShawnR
Does anyone know the pressure flow relationship for an Argon pressure flow gauge? I have a couple of old, pooched gauges. It says on it Argon and "use .032 orifice" which I assume is in the regulator already. I have tried searching but not been able to find a site that would tell me what this gauge is actually showing, ie at CFH, what the pressure is or at 40 or 50 (top end) I understand the concept of differential pressures relating to an orifice indicating flow, just can't find the numbers I need to know what pressure gauge would work here. I found several water ones, but no gas one.
No one in town has them but can order them. I would probably be better off (prefer) to get an actual flowmeter if I was to order something.
Hey @ShawnR : I would suggest you just replace it with a new gauge that has the flow gauge right there instead of a gauge pressure/orifice conversion value. Those gauges are not very accurate in the lower flow areas.
Here is a pic:
For typical welding you will be around 10 to 35 CFH so the gauge will just be off the zero at 5 to 15 litres/hour. Much easier to see the wee ball floating about - just my opinion.
I have this type gauge on my Keg fridge as there typically is very little flow (of CO2) and more interest in keeping the pressure on the keg :) and beer flowing :p
@CalgaryPT : indeed
I was set up for the typical store bought kegs and Eruo kegs (a different bung connector). It was all run out of a 1930's fridge - quite lovely but not something to have in the shop....LOL.
I am building a bar in the basement (delays due to stupid covid wood costs) and will be installing a new draft system from a more modern fridge conversion. I sold the old fridge but kept the keg fittings. I may adapt to the soft drink mini kegs when I retire and make beer again. I used to make beer all the time but it got a bit too much when the kids were small. Now that they are able to drink the beer as well it may be time to start back at it - ;)
Personally I have safety concerns for Brent. All that tubing and CO2 sounds like an accident waiting to happen. It needs a second set of eyes, such as mine, to evaluate.
Sometimes when I am in safety inspection mode I get thirsty.
No problem Gentlemen (using the term loosely) Be sure to give me some advance notice so I can pull permits and make sure my documentation is set up properly. - Donations are always welcome :p
:p
Yes, I agree. That gauge is the style I have, but mine is no good...Thought I might like to know what the actual pressures are. They would be spare regs. Seems a waste to buy a whole regulator to get the flowmeter but the flowmeters alone are more expensive than a whole regulator. I have 2 good working ones now. These are spares that came with old welders.
Yes Tom, I was looking at those. Might be kind of a handy gadget to have around. Then I could figure out my own chart for the .032 orifice. Or verify my other flowmeters, which I suspect are fine. But hey, another gadget for the shop! :)
