By 'fancy' which model do you have? I have the basic DD but have not done carbide, only HSS. I find it to be so-so. It corrects the geometry OK & puts a not bad finish on, But IMO a far cry from the polished look of a nicely ground drill, especially carbide. Maybe I need to investigate a higher grit diamond wheel replacement (assuming they make one). But just eyeballing the finish on HSS bit from my 6" bench grinder using a good stone wheel, it seems more refined finish. I almost wish the DD used little cup stones vs. the diamond coated cartridge, but then you'd have to have dressing provisions & its looking more like a tool & cutter grinder.
Let us know how you make out.
