slow-poke
Annular cutter virgin here....
I see it's recommended to have a spring loaded drive when using an annular cutter, , anyone try this without the spring loaded gizmo. Would the cutter not simply retract and then if the plug is inside the cutter, just tap the pointy pin in to pop the plug after removing the cutter from the mill?
