Tool Aluminum insert turning mild steel
Tool
Larry_C9
A few days ago days ago I was turning down some mild steel round bar to 5mm. The HSS tool I was using was a little large for the job and was not leaving a very nice finish so I grabbed a mini indexable turn tool I had that had a CCGT060204-4K polished insert made for cutting aluminum, which was all I had that was handy and was small enough to do the job. I didn't know what to expect and the insert had many hours of turning aluminum on it already, so if I ruin it there is no great loss. To my surprise it cut the mild steel like butter and left a very respectable finish. I used it that way for a couple of days then thought I should see how the tool is standing up. Under a fairly strong magnifying glass the cutting tip shows no excessive wear and appears to be able to continue cutting mild steel. Kind of interesting
I’ve seen inserts for aluminum used on steel with good results.
Nicely done.
I use the same inserts on steel quite often as well with great success. They won't hold up as well as a CCMT so if I'm doing a lot of steel removal, I will switch, but with only one insert holder for that size, if a gt is in it, and I need to quickly turn down a shaft or something I won't bother switching. They leave a great surface finish too.
This is what quite a few members are finding Larry. I use them all the time in a trigon shape. And like you, I have not worn one out yet. I do think the inserts for steel will last longer, but for hobby use, I don't even know why I bothered to buy inserts for steel and stainless. If I had to do it over, I would probably only get inserts for Aluminium.
