I picked up this used 6" riser block from Modern Tool a couple of weeks ago. Since we all isolated with nowhere to go I have lots of time to install it. I was a little hesitant to do this alone as it seems like a second set of hands would be needed but I'm going ahead with it anyway. I started by removing the DRO display , lights and anything else that might get damaged. The mill sit under my furnace with 7 inches of clearance so it has to be moved forward a couple of feet. Another chance to use the toe jack and skates. To make the head and ram assembly easy to lift I turned the head up side down. To give myself 2 lifting points I had installed a 7/16" eye bolt in a collet and there is already an eye bolt centered on top of the ram. My engine crane has to be extended as far out as it will go to reach and is rated at 1000 lbs in that configuration. I think the head and ram are pretty close to that heavy so I will have to see how it performs. I was quite sure this riser would fit from research done on the web and verified the dimensions I had found that are supposed to be standard for most Taiwanese Bridgeport clone mills.
Ready to lift after removing the 4 long bolts holding the ram to the base.
