A Special Lathe Tool Bit
carrdo
Hi All,
Here is a special lathe tool bit which I have used many times to get one into and out of a tight spot/corner where no other tool bit will do the job.
And if one takes light cuts, it will also leave a beautiful surface finish. This one happens to be ground from a standard brazed carbide tool bit but the same can be made from HSS. It just takes a lot of grinding to produce the slim form.
  • 179 A Special Lathe Toolbit to Get You Into and Out of a Tight Spot.jpg .jpg
I have often used a parting tool to do the same thing for the same purpose. It's a lot easier to grind........
I did exactly this using a 1mm high speed steel parting blade to make a threading tool to cut 11.75mm x 1.25mm buttress thread. now I only need to get lathe finished and figure out how to set pitch to 1.25mm
You sure like to plan ahead don't you!
Can I assume you have a 127 tooth gear on your lathe? Or is that part of the project?
I missed your reply at the time...
I've been told that my lathe can thread 1.25 metric threads but until I get it spinning I can't actually test that claim. Then there is our other lathe which also should turn this thread too.
I hope to get to get to this in september or october because I really need an adapter to fit W12 spindle
