4027 Aluminum
Feeop
So I picked up a piece of 4027 cheap.
Now I'm wondering:
1. Can use it for a desktop CNC bed?
2. I understand it's harder, so what endmills are best?
Thanks
Not sure what AMS means. I picked it up at a fab shop and they said it was 4027 . 12x30 was only $60.
FYI . . .
In the aerospace industry, components must be made using materials that are regulated according to stringent standards. To meet these goals, the Society of Automotive Engineers (SAE) has established aerospace material specifications, commonly referred to as AMS.
It looks like another specification organization cashing in on an accepted industry standard.
From Gemini
AMS4027 is an aluminum alloy, specifically a specification for 6061 aluminum sheet and plate, with a solution and precipitation heat treatment. It's a medium-strength, heat-treatable alloy known for good corrosion resistance, weldability, workability, and performance at elevated temperatures. The alloy composition is approximately 1.0Mg - 0.60Si - 0.28Cu - 0.20Cr, and it's often supplied in the T6 and T651 tempers.
Here's a more detailed breakdown:
  • Alloy Designation:
    AMS4027 refers to a specific standard for 6061 aluminum alloy.
  • Composition:
    The alloy primarily consists of magnesium (Mg), silicon (Si), copper (Cu), and chromium (Cr).
  • Temper Designations:
    It's often supplied in T6 and T651 tempers. T6 indicates a solution heat-treated and artificially aged condition, while T651 indicates a solution heat-treated, stress-relieved, and artificially aged condition.
    • Corrosion Resistance: Good resistance to atmospheric corrosion.
    • Weldability: Excellent weldability, making it suitable for various joining methods.
    • Workability: Good machinability and formability.
    • Strength: Medium strength, making it suitable for various applications.
    • Elevated Temperature Performance: Performs well at elevated temperatures.
  • Common Uses:
    AMS4027 (6061) aluminum is widely used in aerospace components, bicycle frames, and other engineering applications.
