EPaxx
Soooooo..........long story short: I've been searching for a smaller milling machine to get my feet wet as I tackle a couple small projects that I have in the plans. I've located 2 different machines that would probably do me for quite some time, but they each have their own set of pros and cons.
Machine 1: Enco RF-30 with less than 60 hrs on it. Used in a machine shop doing a very specific task in light material. Then has sat unused for a couple years. It comes with a fair amount of tooling. R8 collet set, end mills, hold down clamps, 1-2-3 blocks and a bunch of other stuff. 220 single phase.
Machine 2: BusyBee CX600. Similar to Grizzly G0704. Pretty close to the same for tooling. Not quite as much but.......... Current owner bought it a couple years ago used and it has sat collecting dust since.
Both machines will cost me about the same by the time I get them home. The RF-30 is cheaper but a few tanks of gas farther away. Very close to same $$$ by the time I get either in the shop.
I'm aware of the round column losing registration issues and have seen several solutions online that would be accurate enough for the kind of projects I have been doing as well as the ones I have plans for. With 5" of quill movement I actually probably wouldn't even have to move the head in anything I've done to date. However....... I still debate it over and over in my mind........ I like the more massiveness of it. 660 lbs. Bigger table.
The CX600 is small in comparison. 250 lbs, and has a really small table and longitudinal movement and plastic gears. Would have to change head height with only 2" quill travel. But is a dovetail mill/drill. 3/4hp motor. Closer......less time swallowed in the getting of it. Lots of CNC upgrades documented as well as cnc conversions.
Anyway.......... Any thoughts? Experience either way or with both types of machines.
Thanks
Thanks
