There is a part 1 and 2 btw. Kind of interesting. I've read a few forum articles & CNC conversions but there isn't as much tear down/rebuild detail on our typical Asian hobby machines on YouTube.
Some takeaway points for me:
- replacement spec bearings are not exactly cheap. One may argue he didn't have to replace them all, but I see the point. The majority of cost was spindle bearings & if you're in that deep, maybe just do them all especially with grit circulation issues.
- I was led to believe Jet was predominantly/all Taiwan machines, supposedly better overall quality vs. similar looking Chinese models. This is (hopefully) is true with some of the components themselves. But this unfortunately shows similar corner cutting issues which can culminate to grief down the road.
- the (Jet) replacement costs were significantly more than what he was able to source elsewhere. One I believe he said same spec came from Grizzly. I wonder if cost is related to these particular sizes are more obscure or that's reality for this class of precision bearing? Eventually he found what he needed but seems like 5 different sources.
- this was just the bearings, the gears were deemed OK. I guess just because a machine looks 'ok' on the outside, you have no idea whats under the hood without running it. Just like a project car or plane, could be a money pit time bomb. I'd consider a project machine one day but this reinforces my view that one should have prior line of sight that parts can be available and fits the budget. Either through vendors (depends on vintage) or harvested from donor machines (depends on general availability and price). One can recondition or re-make lots of parts with existing machines, but you cant fix or make a precision bearing yourself & might even be challenged on certain gears especially if they need to be hardened.
Anyways, enjoy. He's kind of an entertaining character.
