Lincoln20XX
I originally picked this lathe because at ~340 kg (750lb) for just the lathe without the cabinet, it was about 100 kg heavier than most of the common (cheap) lathes of similar size.
It's got an installed DRO, 12 speeds, fully geared transmission, metric and inch threads, longitudinal and transverse auto feeds, 1.5" spindle through hole, and almost every option/tool the factory offered.
It's got very few hours on it - maybe 10 or so hours of cutting at most. Unfortunately life is taking me in a direction that means I need to consider getting rid of it.
I don't want to sit on it forever, but also don't want to leave a ton of cash on the table, so with that in mind I'm looking to see if anyone here would give me an idea of what a fair price for this would be. I think getting something equivalent locally would probably be in the $8,000 range? I'd be happy to get $5,000 out of it.
Located in Kelowna, BC. A forklift is available on site to load it onto a truck for shipping, but I won't deal with shipping it.
Comes with:
DRO
Cabinet
Three jaw chuck
Four jaw chuck
Fixed center
Live center
Steady rest and follow rest
Basic cutting tools
Basic drill bit set
Specs:
Swing over bed 320mm (12.6")
Distance between Centres 600mm (23.6")
Swing over cross slide 200 mm (7.9")
Spindle bore 38mm (1.5")
Spindle taper MT5
Cross slide travel 160㎜
Top slide travel 100㎜
Metric threads 0.20~7mm (22)
Inch threads 2 1/2~48 T.P.I. (45)
Modulus thread 0.20~3.5mm (21)
Diameter pitch thread 8~120 1/n″ (31)
Range of Longitudinal Feed 0.10~1.40mm (24)
Range of Cross Feed 0.045~0.60mm (24)
Tailstock ram travel 80mm
Tailstock taper MT3
Number of spindle speeds 12
Spindle speeds 60~1600r/mim
Motor 1100W
Voltage 240V
Amps 7.2
N.W. 340㎏
Overall dimensions 1370×685×520mm
Comes with:
DRO
Cabinet
Three jaw chuck
Four jaw chuck
Fixed center
Live center
Basic cutting tools
Basic drill bit set
Specs:
Spindle taper MT5
Tailstock taper MT3
Motor 1100W
Voltage 240V
Amps 7.2
N.W. 340㎏
