@RobinHood that's good to know. Was there anything special about the endmill type? I've heard the core is a bit softer than outer skin but not for the first 0.2" or so. I'll check with my new fangled (somewhat subjective) hardness files.
I was actually thinking about buying a dedicated (offshore) donor carbide tool for this purpose in case it went 'snap' but couldn't decide between a drill & EM. The EM was actually cheaper but I was concerned about the the delicate EM cutting edges vs. conical edges on drill. One would think a drill would be better at.... drilling? But I have also seen people drill with ball ended EM's.
Actually it was a used 1/2” EM from a tool buy. Was not even very sharp. Lots of cutting oil and slow speed (rpm) and relatively high hand feed to be sure it would make a chip & through it went. I think it was a Niagara Cutter (or some other US made one - I’d have to check for you).
If I were to buy a new, specific endmill, I would get one with a decent corner radius as the one I used did lose its edge. Most probably because it was already damaged / dull. This was a 4F. I would get a 3F or 5F one.
The web on any drill (carbide or HSS) is too thin in my opinion. Good chance of twisting it off once it grabs.
Because of the flute length of the EM I had, I needed to flip the block around and mill from both sides to make it all the way through the hole. (A longer fluted one would solve that problem. ) But since it is just clearance, hole accuracy does not matter and I just eyeballed the center by floating the EM into the existing chamfer.
