Wanted: milling vertical spindle motor - Victoria BC
Birkhoff
Bridgeport clone that got stripped of motors and hand wheels.
Any reasonable flange mount,** 3 ph, 2-ish HP and the Holy Grail would be 2 speed windings, but I'm ok with using a VFD.
**I have to fabricate the mounting plate to fit as the buggers stole that too!
voltage preference?
Right, voltage. 220V would be best. If I have to go higher, looking at a VFD for sure. Not into transformers at the moment.
Budget?
I have a motor rebuilder I can ask to keep an eye out, and I see higher voltage motors pretty often, if your budget is sufficient rewind may be best. A motor will ship cheaply enough
Free would be great but free at a distance not so much. Not too long ago, multi-horse 3ph motors traded at scrap value. Now that I need one they are way more expensive, I guess because of cheap inverter drives. More expensive than single phase! The latter used to be $100 per HP, but now they are almost given away.
I should mention I have $500-ish into the mill so far. There are two ways to think about this I guess. Lots of headroom to buy a good motor, or, ending up with a motor that costs more than the mill :-|
