Steel bar/plate | Other | Calgary | Kijiji Classifieds
9" x 2 3/4" round bar/plate. Trued on a mill. Asking $200. New price is $743.50. Second one is 8 1/2" x 2". Asking $150. New price is $481.00.
www.kijiji.ca
After reading your post, look a bit harder down by the bottom below the left hole you can see a cut mark in it as well. Seems expensive even if it didn't have the holes and a cut in it. It’s been some time since I bought steel, so not on top of pricing.That seems expensive as it already has a couple of holes. Likely some machinist made a mistake and it would have been tossed in the recycle bin except someone piped up with "I'll take it"
1045 HR ROUND BAR 9" DIA - MSP Metals
Material: Carbon Steel Shape: Bar - Round Alloy: 1045 Diameter: 9.000'' 0.125''/-0'' Cut Tolerance. Cut sizes from 0.375'' to 72'' in 0.125'' increments. Please contact us for sizes and tolerances outside of this range.www.mspmetals.com
Well that is a US site so in Cdn. $ it's 108.21 or so per inch. That's $Cdn. 297.17 before smoothing away saw marks. Spend $324 for 3" and remove 1/8" from either side and you have your 2.75" for $324 without extra holes.After reading your post, look a bit harder down by the bottom below the left hole you can see a cut mark in it as well. Seems expensive even if it didn't have the holes and a cut in it. It’s been some time since I bought steel, so not on top of pricing.
