Elektrishun
Installed a speed indicator for my lathe after being inspired by several installations I seen online. There are several different ways to go about this depending on the type of lathe you have. The 9 -15VDC speed indicator comes with a digital display, a hall effect sensor, and a magnet.
Determining how to set-up the speed indicator started with where to place the magnet. My main consideration for mounting the magnet and sensor was to not make any permanent alterations to the lathe. I decided to mount the magnet to a piece of UHMW with friction fit at the opposite end of the headstock (tailstock?). I realized that this would interfere with certain applications like using a drawbar with a Morse Taper. So far, I haven't needed to use such a set-up.
The magnet is held to the UHMW using 2 part epoxy and self-fusing repair tape. When using 2 part epoxy with UHMW I used the advice found here; https://www.usplastic.com/knowledge...I1wCXJGEZEYvjz65BlhFMOD1O5Rd1Dth-gme7LL6-GIBk . The epoxy seemed to hold really well but I decided to add the self-fusing repair tape to ensure it stayed in place.
Built a simple metal bracket to hold the sensor (shown in second photo below). The metal bracket is held in place with a single bolt in the location where I believe the drum switch would normally have been mounted.
There is a 120/240VAC - 15VDC power supply powering the speed indicator. The power supply is plugged into a 240VAC outlet controlled by the same switch that provides power to the lathe.
There were numerous ideas that came and went to get the speed indicator installed. I am satisfied with the install and the speed indicator works.
