a smile
Lifelong hobby - cold iron
I am designing a new mechanical equipment, which needs a special long shaft. Because I don't have a special cyclone mill, I have to find another way to solve the problem. Select crankshaft eccentric car ----
The 4 large circles are machined using wire cutting, then the lathe makes the flange, the milling machine makes the hole, then the tapping. Then a hole indexing difference of 10 degrees, re-punch, low-level error, hope not to repeat!
Make tightening limit block (taper hole)
One end taper wire, surface grinder processing 6 faces
Mount to lathe
Mount to lathe
