I'm tired of my shop vac hose collapsing every time I use it. Is there a recommendation for a hose that doesn't degrade when it sees oil from my lathe or mill?
I'm using the 2-1/2" hoses now as I used to have a vac with the 1-7/8" and that would just end up clogged all the time. Now I don't usually get clogs (once in a while if I'm really lazy and sucking up some really stringy swarf), but now the hose collapses in several places if the end is covered or I bend it just a little bit... Was good when new but the oil has softened it.
Also would not mind it being a little bit longer. Mine is 8ft and I really don't want it shorter. Would consider daisy chain of 2 hoses.
