M10 X 1 extra fine. I used the same as my commercial ones.Awesome . Is that 3/8 NF on the tool height bolts?
The dovetail cutter worked OK. But chip load is pretty high with only one insert. It was a long slow process with lots of small slow cuts. It would probably better with at least 2 inserts.Nice!
I built a batch of holders for my clone of a Tripan Tool post. Similar style dovetailed holders, but much smaller.
Did the dovetail in foot long sections, cut off what I needed and batch processed half an ice cream bucket of them...
Like the home made dovetail cutter, that rocks. And I AM gonna steal the idea for the HSS tooling sub-holder! Thanks for that!
I dunno that a light layer of plating would be noticed, fit-wise. There are a couple different tool blackening kits out there, check out Caswell Plating Supply, IIRC, they carry some of that too.I want to do some sort of finish to protect them from rust. Any kind of plating is out as it would effect the dimensions and fit. Some sort of surface conversion process? Anyone with experience? Suggestions?
I use a salt bath @ about 950F to anneal brass. I try not to waste any of it, but a few drips escape, and when they land on steel they turn it a nice black.I want to do some sort of finish to protect them from rust. Any kind of plating is out as it would effect the dimensions and fit. Some sort of surface conversion process? Anyone with experience? Suggestions?
Can you please post a picture or two of your results?Jax Blackening solution has worked well for me and isn't too expensive. Available in Canada at:
Jax Iron Steel Nickel Blackener
Produces an antique metallic black finish on iron, steel and nickel. Color: BlackenerProperties APPLICATION INSTRUCTIONS Metal surface must be cleaned of all lacquer, oil, wax, and grease. Gloves should be worn to prevent surface contamination. JAX Iron, Steel and Nickel Blackener should be...sculpturesupply.com
Thanks Craig! I'll check it outJax Blackening solution has worked well for me and isn't too expensive. Available in Canada at:
Yes you do. Nice work.OOPS! Now I need a bigger shelf.
Here are a couple of small parts that I already had pictures of:Can you please post a picture or two of your results?
That sounds like a VERY interesting store to wander through!Here are a couple of small parts that I already had pictures of:
I just brake cleaner to prepare the parts before applying the Jax blackener. I believe I did 2 coats on eash of these parts and then submerged them in light oil. I had tried the '1 hour rust blueing process' before and the Jax product is so much easier that there is no comparison. I'm sure I can scratch through the blackening but so far it seems durable enough for what I want.
And if you happen to be in the Toronto area, the Sculpture Supply store is worth a visit just to see the wild stuff they have. They carry a lot of stuff special effects folks in the movie industry use to create masks and set pieces and all other props. Plus stuff for any kind of art sculpture you can imagine. Very near the Kipling subway station. I think they'll do mail order but I have no experience buying from them that way.
