If you haven't seen Robin Renzetti's 123 block design, I attached oxtool video below. Totally cool. These are what 123 blocks SHOULD be. The problem with the Asian 123 'botched blocks' is the holes are either a thread pilot hole diameter or fully threaded & in a non-alternating sequence. Which basically makes them very difficult to attach together. Yo cant put the appropriate threaded bolt through the pilot hole to engage the threaded hole. You can put an under-size threaded rod through, but now you have nut & rod protrusions that may limit clamping or datum surfaces. So these blocks are inexpensive I guess, somewhat attractive, a bit lighter weight, the holes are great for trapping swarf & oil, but otherwise rather useless over a solid block. They are fully hardened so no fun to ream out. And they continue to make them!
I tried playing around with a idea I had. The sketches better show the intent. Basically a through hole dowel pin, a threaded dowel pin & 8-32 cap screw. They can be one hole width apart regardless of stack-up orientation. Well, that was CAD world where everything looks wonderful. In reality its a bit fiddly to position them in the block holes & aligning the fastener holes. A skewer stick kinda solved that. But the bigger issue is the clamping doesn't feel very positive. I suspect this related to pin tangents on hole tangents makes for little contact area and a bit of position sliding until they are cinched secure. Back to the drawing board. Dragons Den will have to wait.
