Doggggboy
Any suggestions on a good Canadian refractory material supplier?
My pool heater kept giving a high flue temp fault and coughing out white dust whenever I tried to start it.
I took it apart and found that the top of the heat exchanger's refractory brick was broken in half and had plugged most of the fins with material.
Vacuumed and blew it clean and put the broken brick back in place. Works fine now but I'm guessing it should be replaced anyways.
Don't feel like spending 180 bucks on a factory one. The brick is quite light and fibrous and about 2 inches thick.
Not even sure what is properly called.
