Okay I have come to the conclusion that cheaping out on no-name countersinks is just an exercise in wasted money.
What range of sizes? Lots of permutations and combinations when you factor in:
HSS, cobalt or carbide?
Single, zero or multi-flute?
82, 60 or 90 degrees?
My current selection of countersinks came from auction box lots. I like how the zero flute countersinks cut steel--no chatter. I don't have enough experience with other materials to have a preference. But I don't think zero flutes are appropriate for, say, wood.
I would, however, avoid BusyBee. Before I got my current selection, I had a project that required countersinks for 3/8" flat head screws in mild steel which was bigger than the lone countersink I had at that time. The BusyBee 3/4" countersink ($9) came a 1/4" shank--which kept slipping in the chuck. Then the flute chipped and folded over before I had the second hole done. Usually I keep broken HSS stuff in case it can be repurposed in the future. This piece went straight in the trash.
YMMV
Maybe @SomeGuy wants to set up a tool test?
I guess 82 degrees is most common?
Size suitable for M4-M8, or 1/4 - 3/8 SAE
The cheaper ones seems to survive in aluminum for a while, so I really need something suitable for steel not sure if I should get HSS or something harder?
And aircraft hardware is 100 degree.Metric flatheads are 90-deg. Imperial flathead UNC/UNF are usually 82-deg. Screws for brown stuff were also typically 82-deg but the world is changing (or has years ago & I missed it). Metric wood screws replacing numbered screws, different head profiles... anything goes nowadays.
Even good CS's can chatter if speed is too high or if unsupported. Low speed & rigid setup usually gives the best results in finish & accuracy. But a cheap CS usually exposes a few potential problems. Usually its a bad grind grind job where the edges are unequal, or wrong cutting angles. If geometry isn't right then it almost doesn't matter what the material is. I'm starting to redress some bad import tools & actually the steel is perfectly good HSS. Some are actually distorted runout you can measure with DTI - as though they were finish ground, then heat treated (vs the other way around). Or maybe when the special miracle coating was applied.I have a good quality butterfield countersink which produce a nice finish on the mill or the lathe. The cheap ones don't seem to work well at all in my machines. They leave lots of chatter marks. Recently I started using them in my cordless drill on the very low speed and have gotten some acceptable results. I think the low speed and the fact I using them free hand allow for correction to find there sweet opperating spot. I wouldn't be surprised they would work even better if I was able to drive them with a somewhat rigid rubber hose, to act like a flexible shock absorber. They don't seem to like rigidity.
It was years before I discovered they came in included angles different than 60* and could be used like that too. Glad I make the connection. That kind of stuff is what makes forums so great for learning.These from KMS are pretty good, I have a set. Irwin. https://www.kmstools.com/irwin-5pc-countersink-set.html
But @Dan Dubeau made a connection in my head I didn't conceive of till he pointed it out in another thread. Thank you Dan. I always thought they just were for starting holes and centre drilling for tail stock support.
These thingsare the same as these but for metal. Ah.
