Carbuilder
New Member
Hi there,
I can't believe I hadn't stumbled on this forum before. I've been on machining forums for a long time and frequently search for machining related sites. Anyways, I'm here now. I live just north of Toronto.
Here are the main machines I have:
CNC router built from Kronos Robotics plans. This is a really nice, solid machine. I've got a water cooled spindle on it. It is mainly used for wood and plastic these days. I did use it for aluminum, which it does very well, but bought a small CNC mill for that now. This runs with Mach 3.
My CNC mill is a Sieg KX1 running with Mach 3. I think this was literally the last one that The Little Machine Shop sold, before they switched to the Tormach ones. It has an enclosure, and I added a mist system and a high speed spidle next to the regular one. This has been a great machine that has made well over 500 parts over the years; I've made a lot of aluminum custom car badges on it.
I have a small CNC lathe, a Taig one that is called a "chucker" lathe. I replaced the control system with a touch screen Masso unit and changed to a controllable drive. Obviously it is used for small parts and the accuracy/repeatability is amazing.
I do have manual machines too, a Precision Matthews mill and a lathe. I'm thinking of adding an electronic lead screw system on the lathe.
I have slowly built up the shop as I got into different projects. These are all for hobby use, but have sold some of the things I've made; the car badges mainly. A lot of the parts I make are to do with car projects when restoring and/or modifying them.
I used to have a Busy Bee 3-in-1 machine. Don't listen to people telling you that these machines are no good. I've made some pretty impressive projects with it, including this one:
Sorry, not supposed to put links since I don't have enough posts....I'll add it later.
My current on-and-off project (ongoing for many years) is a Little Demon 1/5 scale gas powered V8 engine from plans. I have a few videos on making some of the parts:
So that's basically it.
Rick
Rick
