Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
If it is like any of the used surface plates I've looked at that were cheap, it's probably not suitable for use as a surface plate any longer, but it would make a great base for a metal cutting cnc router.
Grade B Mitutoyo plate, worth about 100$. Guaranteed it isn't a Grade B any more, but still suitable for moderate tolerance work. (+/- .001 for example). Anyone with a long parallel (20" and up) can do a light test and see if it is severely worn or damaged.
