Thanks Peter, they are getting scratched up with use, so not as pretty as they once were...
no idea what type of steel it is, other than the billet these were cut out of have red and black colour coding, a date of 1996 (if memory serves), not a speck of rust on them, but are magnetic. i think it is an alloy of stainless steel. It is tough material as I found out the hard way: it ate a 1” SKF, HSS, roughing end mill in one pass because I ran it too fast (rpm too high and not enough feed).
the three smaller ones were done before the SFC Grinder tune up. The others after. Biggest difference: I can now take heavier cuts before I run into the “chatter” marks issue. Only the six outside surfaces of each block were ground, the features are all milled only.
Roughing and finishing end mill for the slots, Woodruff Key Cutter for the undercut (because I happen to have one of the correct size) and a sharp, 4-flute carbide end mill for the Vs with the blocks set at 45* in a vice.
