A little correction on the bearing
I would stick it in the TS and grind the tip in situ - should be near zero run-out after that.Are you going to evaluate the runout?
Yup. Use a rubber band or similarly fashioned around the TS center and on the OD of your cordless drill chuck.I would stick it in the TS and grind the tip in situ - should be near zero run-out after that.
A picture is worth a thosuand words.That is gunna take more splainin....
The 6203 bearing is of normal tolerances no need to get a high precision bearing as I seldom go above 600 rpm unless I'm polishing which is not often.6202 P4 / P5 spec 5$?
You don't turn non ferrous much?The 6203 bearing is of normal tolerances no need to get a high precision bearing as I seldom go above 600 rpm unless I'm polishing which is not often.
