Lathe setup and Projects to come.
Redneck7
Well I haven't posted in a while. I got the lathe swapped over today to a better bench that's more stable. It's rated for 3k pounds and my manual says my lathe is 1074 pounds. If I notice the wood top sagging, I'll install some runners along the 3 bolts in some stout angle iron.
I got my QCTP installed and it should do just fine for my purposes until I get more serious. It's an accusize from Amazon, Wedge style and I have more than enough tool holders now.
Tomorrow is gonna be the day that I get to make some stuff. Couple small pins for my friends rifle. Starting my outboard spider as well. Then when I get a chance, install plastic inserts on my set screws.
Nice. In in ideal world it would be better to have cross members oriented to the mounting pattern & integrated to the peripheral frame. Then the tabletop becomes just a secondary surface as opposed to carrying the structural load. Alternately some people beef up the thickness by laminating more wood if its a no-weld type deal. Do the feet have some form of adjustment where you can jack them up & down a bit? That will inevitably be necessary.
Looks good. I have that same Husky work bench with 2 Dillon presses on it. I ran a couple of large screws thru the back support into wall studs for a little more rigidity. Rock solid.
The feet are adjustable. I was going to make a new bench yesterday with some scrap steel and figured this would just be easier. The frame of the bench is pretty light but wouldn't be heard to do what you're suggesting in the picture.
I'll see how she spins today, mounting to the wall wouldn't be a bad idea either. Thanks guys.
