Rauce
Clearing out some stuff!
Do-All 6" mill vice with handle. Serviceable, some surface staining and a few apprentice marks. $100
Semi Finished D1-6 Backplate, 10"diameter I think (can confirm). I believe it's shop made and the pins were taken from a broken chuck. $40
TMX 8" 3-jaw chuck D1-6 Direct mount. Definitely seen some use but works okay, the hard jaws could use a re-grind. I found it very repeatable using soft jaws. Comes with chuck key and 4 sets of soft jaws. $200
Jacobs 96-F1 rubber flex chuck, has a plain back. Two sets of collets, one full set and one set that is missing two collets. Has plugs for most sizes that are used when chucking short workpieces. $250
Cast iron square rough casting 16" x 8". Could be a fun project for someone with more spare time than me. $100
Mystery dividing head, possibly Russian? Has a swivel base, dovetail on the top is for a missing over arm support/center. Spindle nose is threaded and I have a 100mm 3-jaw chuck that goes with it. One plate that fits it and two more plates that don't but could maybe be adapted. $100? Open to any reasonable offer on this.
