Was asked to machine up a backing plate for a buddies Clausing lathe so he could mount a 3 jaw on it (It only came with a 4 jaw).
Rough machined the plate to about 0.050” over, then cut the tapered bore after tramming the compound slide and finished with the threads.
Wasn’t happy with the finish of the bore, had some chatter I just could not get rid of. Tried everything. Even tried a stone in my air grinder clamped the the tool post. Side note, don’t try that! If it’s a problem, I will just borrow the tool post grinder from work and clean it up.
Used 1045 steel. Machines up nice. Hadn’t used it before.
Going to blue it up on his spindle before I cut the keyway, see how it sits.
Nice project though
Nice project though
