It's been over a year since I finished my last bike project and I have been feeling like taking on another one lately. I picked up a running 1972 F9 along with a non running parts bike at the Red Deer swap meet a few years ago so hopefulky I wont break the bank buying parts for this one. It will need a new chain and sprockets but I have not been able to find reasonably priced sprockets in the original ratio so I decided to make sprockets using common weld-on ones available at Princess Auto. I picked a 42 tooth and a 13 tooth to match the originals as closely as possible. They fit common agricultural 50 chain but will also fit 530 motorcycle chain. On the 42 tooth rear I bored the center hole to 47mm and drilled six 10.5mm bolt holes on a 104.5mm bolt circle. Then I added six 34mm holes on a 146mm bolt circle to match the look of the original sprocket. My plan is to strip the black finish and zinc plate the new sprocket. Here are a few pics of the process.
The first pic shows a 47 tooth and a 41 tooth from the 2 bikes I have along with the original 13 tooth front and the 2 weld on sprockets from PA.
It fits the wheel hub with the 47mm hole bored.
$25 for the weld on sprocket and a few hours of quality shop time.
