Brent H
# 2 son is working his butt of as an HVAC contractor and is pretty much on the go all the time. He had a very loud engine compartment and we took a look - exhaust header split in half at the catalytic converter :
so I got all the pieces out, bolted it to the welding table and welded it all back together using the high nickel mig wire - took a while and I let it cool between welding stitches.
after that - how to make it flat and true - good ol Bridget and a a wack of supports!!!!
Yes - that backwards nut on the threaded rod just put enough on the flange to take out vibration and not distort things. The whole contraption is sitting on 3 blocks and then I jacked up one end to make the header flat in the x axis - bolted it all down solid and then rotated the mill head to be at the same y axis angle.
the passes averaged about 3 thou per pass and I had to take 0.045” off to get all the flanges clean and true
Hopefully after a new gasket it will last at least long enough for the boy to decide on a new truck or dump $600 on a new exhaust - I think he gets a core return.
Love the mill!! Woo Hoo!!
