TorontoBuilder
Over the last two days I wired in a new 240 volt 30 amp circuit for the rotary phase converter, and the wired and tested the RPC, and today wired the surface grinder to the transformer.
Then we opened the back and cleaned old dried out grease from the vertical ways, and cleaned and regreased the lead screw to elevate the spindle. Then replaced all the hydraulic fluid and stuck some head stock oil in the spindle just to be able to test things out.
The hydraulic feed worked fine for a while, so we tested the spindle briefly. Then both together and things were running fine. Then I went to do a full cross traverse under power and at the end of the traverse I couldn't figure out how to change the direction of travel back out. I am unsure if the limit stop was hit but the surface grinder shut down and would not restart.
I tried turning it off and on repeatedly. I shut down power and checked all the fuses. I broke out the multimeter and tested the 600V 3 phase output. Everything was fine.
So after farting around I went to retry running the grinder. It ran and completed one traverse on two test parallels and at the end of the traverse shut down again. Would not restart.
so my theories are that there is a thermal overload shutting down the grinder, either because the spindle oil is too thick, or the hydraulic pump has shut down. Hand cranking the longitudinal feed is very stiff. Or maybe air in the hydraulic system... or something in the traverse direction change has a shut off we done grasp yet.
Tomorrow I'll try some more. Read the manual much more fully.
Likely we will do a little long delayed grinding work with this and then do full restoration.. there is a motor to raise and lower the head... it lowers fine, but bogs down after 6-8" lift of the head.
