Hydraulic metal bandsaw
Bbrackish
New Member
Located in Vancouver, BC
No shipping/ pickup only
$900CAD
The Magnum Industrial UE-712 7" x 12" Metal-Cutting Band Saw sets the standard for reliability and performance.
This band saw is easy to operate and maintain, and its heavy-duty cast frame provides long-lasting performance in tough work environments.
Features include vertical head locking with auxiliary table for vertical scroll cutting; built-in coolant pump, tank and recovery tray; heavy-duty wheels; and adjustable blade tension and guide bearings.
Powerful 1 HP motor with four speed settings handles a range of metals Heavy-duty cast frame provides long-lasting performance Locking head and removable auxiliary table facilitate precise vertical cutting Quick-lock vise secures workpiece when cutting angles Blade tension, guide bearings, and hydraulic down-feed control adjust easily to suit your project Coolant system features built-in pump, tank and oil recovery tray and fine adjust hydraulic feed control
Automatic shut-off Includes chip brush and safety guard Specifications: Cutting capacity at 90º (Rectangular): 7" x 10-7/8" (180 x 275 mm) Cutting capacity at 90º (Round): 7" (180 mm) Cutting capacity at 45º (Rectangular): 4" x 7" (100 x 180 mm) Cutting capacity at 45º (Round): 4" (100 mm)
Blade size: 3/4" x 0.035" x 93" (19 x 0.9 x 2360 mm)
Blade speeds: 86, 132, 178 & 260 feet per minute
Base dimensions (l x w): 51" x 20" (1295 x 508 mm)
Overall dimensions (l x w x h): 49-1/4" x 27 1/8" x 40-3/4" (1250 x 690 x 1035 mm)
Motor (pre-wired 120 V): 1 HP, 120/240 V, 1 Ph, 9/4.5 A Weight: 330 lbs (150 kg)
