Hi Kelly,
looks like you have another nice project on your hands. I’m sure it will be beautiful work as ever...
here is my take on large chucks:
* if balanced, they are great for increasing the surface finishes of your work as there is more mass in rotation
* you can safely clamp larger workpieces without the risk of the jaws being outside their safe engagement limit
* you can run the carriage into the chuck as it will no longer clear it
* they are harder on the gear train if there is no way to accelerate/decelerate them in a controlled manner (a VFD or a clutch helps, so do belts that slip a bit)
* in a screw—on spindle like the Atlas, it could come undone easier than a lighter version because of its mass together with a fast decel rate
* etc.....
i looked up the bearings that are most likely on your lathe:
they are probably Timken 16000 series for the front (16150 cone, 16284B cup) and 14000 series for the back (14125A cone, 14276B cup) of the spindle.
the basic ratings are as follows (here is the link for the front one
https://cad.timken.com/item/tapered...gle-cones---imperial/16150#Basic Load Ratings )
C90 Dynamic Radial (90 million revs) 3300 lbf
C0 Static Radial 14800 lbf
Ca90 Dynamic Thrust (90 million revs). 2270 lbf
and for the rear:
https://cad.timken.com/item/all-pro...rings-ts-tapered-single-imperi-2/14125a-14276
C90 Dynamic Radial (90 million revs) 3180 lbf
C0 Static Radial 13900 lbf
Ca90 Dynamic Thrust (90 million revs). 2080 lbf
from those numbers, running the larger chuck is no problem at all as you will never likely get close to the bearing limits.
as far a proportions of the chuck vs the lathe, that is a whole other story....
Cheers, Rudy
