Image 1 - I attempted to clone a shim punch for punching shims from 8 thou steel shim stock.
Image 2 - A punch set I borrowed to clone. It works quite well.
Image 3 - My first attempt. It produced one useable shim and the proceeded to mangle every one there after.
The ID punch works fine. The OD punch not so much.
Image 4 - I attempted to re-do the OD punch two more times, including lapping the punch to the die using valve grinding compound. No luck.
Soooo, I'm at a loss now as to what to try next. Wrong materials perhaps? I used steel plate and round bar scrounged from the MSM per pound scrap bins. Tolerances not close enough? The die was drilled on my crappy table top drill press, the punches were turned on my 7X12. I milled the die plates with a step rather than using washers to separate the two plates after I got my mill. That didn't help.
Thoughts?
