Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
I think its worth pointing out that most garage/home engineered trusses or upper floor wood I-beams are not meant to have weight of this kind suspended from under them. Maybe 200-300 lbs of garage door+track at most.
I'd certainly be investigating what kind of structure I'd need in place to hang not only a few hundred pounds of track and cable hoist from, but also an additonal hanging load the cable hoist might be able to lift.
I'm not a structural engineer, but have worked with enough of them (commercials and residential) on various projects to have a vague idea of whats entailed.
100% agreed. If the structure above was designed to support dead/live loads hanging from below, more than your typical garage door weights, then all is good.
Engineered roof trusses, assuming thats what the linked hoist+track are hanging under, are only designed to take large loads from above. Like snow loading or dead loads of sheeting plus shingles. Hanging dead loads on the bottom chord of a typical roof truss are intended to be ceiling drywall and the weight of insulation above. Theres obviously some 'wiggle room' as garage door tracks and the garage door itself (when opened) are also capable of being safely carried by typical roof trusses.
