I need some basic guidance regarding motor controllers for dc motors. I'm browsing through Aliexpress and the lack of my knowledge combined with the poor product descriptions makes it a gong show.
I've salvaged a small 90v DC brushed motor from a treadmill. On the motor it also says 450 watt, 5.5 amp and 3700 rpm. I don't know how accurate these rating are but from what I gather it would be considered an extremely underpowered motor for a treadmill.
I'm considering a project for this motor and realize that the end use of the motor would likely determine the type of controller I would need, however I think the two distinction would be foot control vs panel control.
Tool post grinder, seeing machine or a bead roller are a few of the possibilities that I might try to make use of this motor in. The tool post grinder scenario I think is the most likely one.
I don't see any controllers on Aliexpress that list 110 volt, they all appear to be 220 volt? Can those be used with 110 volt?
It also appears that some controllers have to already have dc voltage supply? I need to go from 110v ac to the dc voltage.
My 90 volt specifications on the motor seems a bit unusual. Can I use a controller with higher dc output without immediately frying the motor?
