Hi, I just got my first lathe - a new CX701 lathe from Busy Bee. I'm mostly loving it, but the three gearbox levers are very jammy. A few questions that the manual doesn't seem to answer:
- Should I be changing my speeds with the spindle running or with the machine stopped? How do the gears mate/select? I guess I could take it apart to find out, but I'd rather not.
- Relatedly, can I change from forward carriage travel to reverse carriage travel without stopping the lathe? For metric screw cutting it's annoying to turn off the machine each pass to move that lever. So I expect that you can change it live, but I'd hate to mess up my transmission.
- Should I be selecting lead screw vs carriage travel running or stopped?
- Is there a way to lock the spindle?
Turning an adapter for the QCTP is turning out to be a really fun first machining project - the Slow Change TP is definitely showing it's deficiencies.
Thanks,
Paul
Thanks,
Paul
