Chicken lights
Forum Pony Express Driver
Pretty simple, how would you guys cut those slots out?
Also, how do you measure the center of an existing hole?
The parts pictured go together, so the slots need to be reasonably close
Thanks!
Yup! Measured at 5/8” and scribed a line across with a punch, using a straight edge.Did you centre punch before drilling?
I said “dumb” questions!
I still think a fence on a drill press would work to help keep my holes in line. Like a mill, that way one axis is fixed. As long as it’s squared up properly?
We can forget I asked about chucking up a carbide burr
In the interest of safety I kind of dropped this idea. I agree that “probably” this could work, but this “shouldn’t” be tried at home without supervision.John and Janger are both right in a "perfect world" but seldom are we hobbiers in that world...the fact is your idea of a fence bolted to the drill press table will work but I "would" use a fine fluted carbide rotary tool/burr (no upwards or downwards pull to work piece or cutter) with straight flutes instead of a spiral mill cutter and feed very slow . With a very slow feed of the work piece into the cutter I can't see that thin of sheet metal doing much damage to a spindle guide .
